B
BlueAgave66
How much horsepower increase and change in acceleration can I expect from installing a MSD 6A ignition system on my ZZ4 355hp engine in a '66 coupe? Thanks
I have to disagree on this.they are olnly prperley set up for a short time.Point start to wear out imediatley.Also above a certain rpm they float.myonnone said:How about none. A properly funtional non-elecronic ignition system will perform equal to its electronic brother. Yea, sure high spark voltage, more consistant dwell, ect, but you should not feel the difference and it will certainly be hard to measure the differences.
I have decided to go 100% for judgingBLACK MOON said:I bet they loved that little trick. They could have been doing great burnouts in the parking lot had you not done that. You and 67 heaven ought to get together. He's looking for a MSD setup. That is if Blue66 doesn't offer to buy it. I can understand your decision but it is only a 30 point deduction if you keep the original shields.
as for your item #3, 2nd part (going back to bia-plys) - bet your opinion changes the minute you drive the thing.IH2LOSE said:I have decided to go 100% for judging
1-remove hurst shifter
2-remove aftermarket hidden stereo
3-remove after market knock off wheels and radials and go to hub caps and bias ply
4-Remove MSD system
As they say on tv "this is the life we chose" I feel strongly about getting this car back to 100% factory correct. we will see if my opion changes after judging
4-Remove MSD system
Miami Stingray,Miami Stingray said:I recentley had Lars rebuild my stock distributor. What a big improvement. My 300hp 327 was plagued with uneven idle and slight miss at upper rpm's. I chased this problem for a year. Replaced a lot of good parts.
Guy's don't forget the distributor, I found out the expensive way.
Lou
