Elliott
Just bought a 1979 Corvette and discovered when the engine is warmed up and driving at highway speeds the hot air just pours into the car from under the dash. Makes it nearly intolerable to drive. Sounds like there is a vacuum water valve under the hood that shuts water off when the heater doesn't call for it. We don't have vacuum to that valve so my mechanic is wondering if there is a control switch under the dash that may be bad? Don't have a parts manual yet, but have one ordered. I've read where some owners with cars that do not have a/c resort to in-line shut-off valves and have had good luck minimizing or eliminating the problem. Mine has a/c, but am also considering the shut-off valve option. I also realize that I may have a damper malfunctioning under the dash, but am not thrilled about tearing into it. Our concern is whether installing shut-off valves may not totally solve the problem if there is some residual heat that may still come through the ducts. So before we tear into the dash, I'm wondering if anyone has had experience with this problem. TX
