Craig-o
Help!
After having tires installed, I started to get a bit of a shimmy when braking. Although I specifically requested hand torquing the lug nuts, I'm sure they used an impact wrench and bent the rotors.
No problem, brake pads were such a cinch to replace, I'll just pull the rotors and have them machined. But wait, how do I get the rotors off? It would seem that I must remove the brake caliper mounting bracket, but I can't budge either the top or bottom bolt holding that bracket on. Is there some trick to this, or do I just need more leverage than I'm getting?
Any help is appreciated.
Craig-o
Craig-o
