I have a 1960 that has the temp gauge reading about 215 when warm.
I have IR'D the motor and it is constant at 180 degrees. I have just replaced the sending unit from autozone as recommended with a tu-6
the readings are the same. (Maybe slightly higher -5 degrees) but still constant on the gauge. I suspect that I have a faulty gauge. Can you direct me on a trouble shoot on the 60 gauge to be certain? The unit reads 0 with the sending wire disconnected and "pegged" with the unit grounded. thanks for your help, vinny
