85redvett
I'm trying to check the resistance on my injectors but can't figure out how to remove the wiring harness from the injector. This is a 1985 vet.
Wires new in June, meant to do plugs at same time but kept putting it off everytime I looked at the num 8 plug.... You would think they could have made some room to get at that plug easier... Engineers don't change plugs... Changing plugs is on the menu for today. ThanksHave you done a tune up? Spark plugs, wires, cap lately?? What about the Throttle position sensor? They are sensitive and can develope a "flat spot"
WOW!Changed the plugs, most were in good condition. #6 and #8 were a fouled up mess. New plugs in and my baby running like new, better then ever! The good news is everything I did before this really needed to be done so I didn't burn cash chasing this problem.Wires new in June, meant to do plugs at same time but kept putting it off everytime I looked at the num 8 plug.... You would think they could have made some room to get at that plug easier... Engineers don't change plugs... Changing plugs is on the menu for today. Thanks![]()
