Viet Nam Vett
- Joined
- May 28, 2004
- Messages
- 2,410
- Location
- Egg Harbor Township NJ
- Corvette
- 65 BB 502 Cp /MSD ATOMIC EFI/ 2009-HUMMER H2
Rebuilding my heater box and replacing the core. The Instruction sheet that came with The "Doc Rebuild Heater Rebuil kit" Shows two thick heavy Black Gaskets that are shown on the Engine compartment side. There is also another thinner Gray gasket that goes inside on the heater box inside the car.
The Doc Rebuild Instruction sheet says tha some years use 2 heavy black gaskets as per the above on the motor side and some only one. The 65 AIM shows 2 also .
Now here's the rub ..I did a test fit on the bench and it is very hard to try and put the motor cover on the heater box. Infact I was afriad to force it on .
Wht should I do here...??? Use 1 gasket or 2 on the motor side??
What did they do at the factory from 63 thru 67 1 or 2 gaskets???..John Z..
Or Bill B....Answer Please
