vdogamr
My engine's cooling fans don't come on at all. There is a thread where someone posted a page of the Haynes manual on how to test the switch, relay, and fuse of an 84. I tried to follow it but ran into 2 problems.
1) How to properly ground the switch connector. I tried to ground what I thought was the switch. (It was between 2 cylinders and had only one wire running to it. ) Below it I saw a black wire bolted to the frame. I tried that. I also tried connecting my volt meter to the wire and to the neg battery terminal and got no reading. Yes the key was in the on position.
2) Where is the relay on an 88? There are several things in the location mentioned and none of them look like the image in the book. And does "jumping the relay" mean to close the circut with a copper wire?
Sorry if I sound like a total ameture (I am), but electrical testing scares me. I had a bad experience where a car I owned had the battery cables colored backward. Replacing the battery was... exciting. And I know shouldn't just go short circutting things to see what happens. I did take off the fan and hooked it up to some direct current and it turned.
Any help would be appreciated. I did order myself a copy of the Haynes manual. And I have the Chilton and owners' manuals.
