JOHNNYB
I was wondering how to adjust tps sensor mine is really loose and it making car idle high.
Thanx
Thanx
boomdriver;1018931[B said:First step would be to make sure both bolts can be tightened,[/B]]F otherwise the adjustment won;t last. If you observe the way that the TPS operates, rotate the body to get the lever almost to the starting end of its range of motion. Thats just a guess but it will be close enough until a voltmeter can be used to set it to spec. When a meter is connected on the top and middle wire in the 3 wire plug, set it to a reading of 0.55v idle. Lock down the 2 small TPS mounting bolts.
Idle should self adjust after that unless there is some other issue, like vac leaks or timing.
Used TB may be a better option, if you rethread the holes nextsize up the bolts will probably be too big for the TPSI THINK THE PREV. OWNER MUST CHANGED TPS AND LOST SCREWS AND REPLACED WITH REG FLAT HEAD THAT STRIPPED THREADS ON TBANY THOUGHTS?
Corvette Action Center Knowledgebase :: 1985 - 1991: Technical Article: How to Adjust your Early C4 TPS and Idle SpeedI was wondering how to adjust tps sensor
Corvette Action Center Knowledgebase :: 1985 - 1991: Technical Article: How to Adjust your Early C4 TPS and Idle Speed[/QUOTE
THANX FOR ALL THE ADVICE LOVE THE TECH ARTICLE WILL DEFINITELY USE IT
I got one of those TPS wire harness kits that let you hook it up to a multimeter. Alot easier than trying to back prob.
