How to fix weirdness...
T
Torchy2000
For those of you who might have seen my posts over the last few months, regarding; no start (1 in 5), codes being set (didn't see my Passkey™), gas gauge reads Zero (if filled past half-way), security light on dash (periodic lighting)...
Changed my Battery and *Poof*, it's all working perfectly!
..."all the little gizmo's just started whirring away...":Twist
Torchy
danl72
Chatsworth, CA
2008 C6 Coupe
Cool. Now you don't have to worry about all of those things not working properly. It can get annoying I'm sure.
S
SilverMN6
I think you just discovered how to re-boot a computer...
D
DkBG
Wow . I can hardly believe it . I wouldn't think a slight decrease in voltage would do all that . I bet alot of members will be buying new batteries now . Thanks for the update !
E
E-Chick
Me too...
The fuel gauge, tire pressure monitor, check engine light, and occassionally, the memory settings...were working improperly and driving me to drink! Turns out, the battery needed to be replaced...love that warranty!
S
shfmd
Yes, but...
My battery was also replaced- 99 with 12K miles. Gas gauge, door lock, tire pressure have never worked right, and various pieces now replaced, so far so good. But I never replaced a battery so fast before- is this to be expected, to replace battery every 3 years?
This car makes my SAAB seem cheap to maintain
D
Drewser
Orange you glad
that you didn't change out that ignition!
Glad you found your problems.:D
