B
		bullrhider
The trunk lid springs on my '59 need to be replaced... they barely hold the lid open. Looks like a pretty straightforward job. So I got some new springs and... I'll be darned if I can figure out how to get the old ones off. I removed the nut on the bottom of the guide rod but the lid won't open far enough to allow the rod to come out of the hole at the bottom of the bracket. The top nut (the one in the u-shaped bracket attached to the lid support arm) seems inaccessible and the nut below that is screwed down to the bottom of the threads. I give... what's the trick? Any help will be appreciated!
