- Thread starter
- #21
M
mike 1985
not a doc
I run a specialized cat scan machine for the heart
mike 1985 said:who did your chip, as there are many people out there that advertise that they do them
:svettedoc said:I took a stock 1989 conv with a 6 speed tranny, 3.54 rear, and added a K&N air filter with open face plate, Walker SS Ultraflo mufflers with new rear Y-pipe with pressure balance cross tube, and Performance chip for the ECM( I have a hypertech street runner which came with the car and a custom chip from Jeff). Can anyone tell me what the HP and torque increase is with this setup?
Mad-Mic said:CKA,
is that car rated at 240 hp and 350 torque?
I am pretty sure it was that high, I played w/ the detent for awhile and it did help some - I will check next time I take her out...Mad-Mic said:it shifts at 5600 rpm in D? did the chip change the shift at all? mine shifts from 4600-4800
in the doghouse... Now it is snowing so, maybe in a week or so, I will check
Eagle85C4 said:I can't say it enough....EBAY
I got ported and polished intake for 100.00, edelbrock runners for 75.00, new plenum for 90.00, edelbrock cam 2101 75.00, aluminum heads with centerbolt valve covers for 500.00, hypertech chip for 25.00, high flow waterpump 45.00, fuel pump 40.00, 24#injectors for 125.00, 1.6/1.52 aluminum roller rockers 50.00 (crane), double roller cloyes timing chain with sprockets for 20.00.....1145.00 so far and if what I have been reading is correct I will add over 100hp....
The deals are there...you just have to be patient and spend a little time searching...
I can give lessons .....
Wow Eagle, that's some good shoppin' you done!
