rdgfx3
I knew it,Iknew it,I knew it.
It's happened before so I developed a system.
My system failed.
Since I tend to forget which part or nut or bolt etc. came from,I label them and put the items in a plastic compartment box,so each item has its own place and the compartment is labeled.
It's worked great for me for a long,long time.
I have a bracket and I have no idea where it goes.I took too much time between disassembly and reassembly.
I marked it 'A/C bracket'
It is a piece about 10 inches long with a slight angle on one end and a cutaway at the other end.At least I know the cutaway end is going to mount very close to something that is in the way.
The factory manual *just doesn't have enough illustration*on this particular job.
ACK!
Uh,I may be putting out a help call for a D/FW area 1990 L-98 owner so I can look under their hood and see what I goofed up.
BTW,This is the water pump replacement job I started and ran out of time before I could finish.My hoses STILL haven't arrived at the dealer,but I figure at least I could start putting it back together. Yeesh.
I would still DIY than let someone else do it.
My system failed.
ACK!
