I didn't have a chance to get to it today, but will tommorow.
I think that you mentioned in past post that you had replaced the cam, lifters, push rods and the like. So I guess that the possibility of a collapsed (can't remember the proper term now) hydraulic lifter is not the cause. They need to be soaked in oil, but I think that your better brands may not require this.
Springs? cam lift too high for head?
Yes I did. It has new lifters and springs that match the cam. I am looking at the cam card and the lift on the intake .477" and exhaust .48". It was a kit that I bought from Comp Cams. I have the stock heads, 462 castings I believe.
I don't think it was a requirement to soak them in the oil, but I did it anyways figuring it wouldn't hurt to do it. I used cam lube on both the cam and the lifters. I also used dyno (non synthetic) oil for the break in for 15 min @ 2k rpm.
So with the valve train it's quite a "messy" oil lubing process therefore the need for the vavle covers to keep it all in?
Yup its a pretty messy affair if the engine is on. There is oil squirting all over the place to keep everything well lubricated. My camera is on the fritz. The software does not want to recognize the camera :confused. I will try and get pics for you TR.
It's a shot in the dark but sometimes ticking is only an exhaust leak at the exhaust manifold. Check all of the bolts for both sides of the exhaust manifold and feel around to see if you can hear or feel an exhaust leak.
Thats what I thought initially. In fact the guy who did the exhaust welded it to the frame and the weld broke leaving a hole the size of a quarter in the exhaust. I patched it up and when this new sound started I thought it was exhaust. I listened but its not a raspy sound typical of exhaust leak. I will check again anyways, doesn't hurt.
Last time I heard a knock like that, it turned out to be loose bolts on the flywheel. The flywheel's bolt holes apparently got a little larger and caused an imbalance. I'm guessing too much torque applied between engine and trans applied. Engine never missed a beat.
Funny you mention flywheel. Just recently when I have my foot pressed on the clutch waiting for the light to go green you can hear a squeaky sound. Kina like something is just barely rubbing but with a high pitched squeak. Dunno, any quesses?
Thans for your guys replys. Diffenetly some other possibilitys.
Gerry LP Good News!! My fiance is going to get a position at Sandia. They are in the process of putting it in writing. So it looks like I'll be moving up to Albuquerque. I am also working through her contacts to get a position up there of some sort. As soon as we get the "official paper" we are going to start looking for apartments up there. Things are finally looking on the up and up
Frank
