fine69
- Joined
- Dec 12, 2004
- Messages
- 975
- Location
- Maryland / D.C.
- Corvette
- '69 Convertible Vette; '72 Z28 Camaro Rally Sport
I want to replace Edelbrock AVS with Q-Jet
Well I decided to replace the Edelbrock Thunder Series AVS 650 cfm carb. I've never been too thrilled with it. First, the primaries appear way too big for street driving. I like the idea of Q-jet's small primaries and large secondaries to be activated when needed.
Can't seem to get the fuel mixture just right, and with fuel back pressure issues, I do not want to use an electric fuel pump. I want to replace the carb with a standard Rochester Qudrajet carburetor. I also want to replace the braided steel lines with the original steel stock fuel line system --- the one that has the filter and the overflow "return" fuel lines.
I should also replace the Edelbrock fuel pump with the stock one, no? I don't think the fuel lines are the same.
I contacted someone who can rebuilt a Q-jet with the electric choke correct for my '69. Without a core, he'll charge me $275, plus shipping. He needed to know some specs from my car such as headers, and camshaft.
My engine has the Edelbrock Performer intake manifold, and Edelbrock Aluminum Performer RPM 64cc heads. I was planning to use the Performer manifold, but still have the stock GM intake manifold - just not sure how this setup will work with the aluminum heads.
Will the Q-jet install and perform well with this setup, or do I need to use the old GM manifold?? Which should work the best? Any comments are appreciated.
Ralph:W
Ralph:W
