Got extremely irritated at my inability to reach the lower connector for the IAT/MAT sensor, coupled with the realization that the sensor harness connector was not the same as the connector on the other end of the harness, so my plans to make an extension cable wouldn't have worked.
Time for Plan B (tm). Man's best friend - a wire coat hanger. Bent the end and used it to hook the connectors under the distributor and disconnect them, then widened the hook to hold one connector in place while I was able to snap the new cable onto it (at this point, Sothpaw arrived just in time to hold the flashlight). Working under the distributor is *not* fun.
Anyway, it's done, and thanks for help/suggestions from the crowd on my earlier thread of frustration.
[RICHR]
[RICHR]
