CPN
Need some help - been lurking for a long time – time to post. I bought a '64 corvette a year ago. I Love Vettes - My dad had a '63 coupe in the early ‘70s (Powerglide 300 hp car) and a ’74 coupe (L-82, auto) while I was in high school (I’m 35). I was looking for a clean early ‘70s car (‘70-‘74) because that’s what I thought I could afford for a long time when I came across a number’s matching (except the rear end –from a ’67) 1964 coupe. L76, 4speed, power brakes with a respray (resale blue) but not much else. Looks great from 10 feet. Out of my price range, but life is short and the car appeared mechanically solid – no rust, straight, no hit body, all the parts except ignition shielding there. So, I love the car but I never thought it ran right. First problem: wouldn’t rev past 4700 rpm. Pertronix ignitor and new coil fixed that. Next problem: real driveability issues. Stall at stoplights, needed to idle at 1300 rpm, didn’t pull like I thought is should, hard starter… Partial fix was a rebuilt brake booster to correct the vacuum leak. That fixed the stalling. I started reading up about carb tuning here and adjusted the float bowl level, the idle mixture and a few other minor things (ensured pedal to the floor was really WOT). This also helped – but I still did not think I was getting full performance. Oh – by the way, I removed the valve covers for a look around. Guess what I found – hydraulic lifters… <o
></o
The more I read, the more I thought my problems were ignition related. Out came the timing light, off came the vacuum assist. Things were a bit off – I dialed it in to have 36 degrees by 3500 rpm, vac advance can disconnected (running manifold vacuum). Ran better, but now it surged and bucked like nuts and had this maddening wandering idle. Some of you have probably figured out where this ends up by now. Courtesy of this and another forum (some of Lars’ papers) I checked out the vac advance can. Stamped plainly on it – B1… the wrong can. I put a vacuum gauge on the engine and I was pulling about what an L79 should be pulling – that hydraulic cam again, I’ve begun referring to the engine as an L771/2. I put my squeezy vacuum gauge thingy on the can to see where it engaged. The wandering idle was because the engine was sometimes pulling the can open, sometimes not – advanceing the timing, slowing down and speeding up the idle. The last guy (we’ll call him bubba) ramped up the idle speed to get the engine into mechanical advance, cancelling out all the screweyness caused by the wrong can. So, I bought the can for the fuelie / L76 327. That proved to be a bit too much. Next can – the one for the L79. Hot damn did that work. Some carb fiddling, the right vac advance can and correct timing… amazing. No knocking (there was some light knocking under accel in 3[SUP]rd[/SUP] and 4[SUP]th [/SUP]when I had the second can on it) anymore and finally I was getting the wave of top end power these engines are supposed to make. I still suspect the spring that regulates the secondary’s action is too stiff. I’ll tackle that and jetting later. Drove it and was back in love with the car. Then I started getting knocking… and more… back to the timing light, reset to 36 all in at 3500… got it out, drove it, same creeping advance. I am convinced the distributor hold down is tight and have not been driving or working on it for a few weeks due to work and weather, but what the heck? Am I just missing something or is this symptomatic of something else wrong. Just looking for some thoughts before I declare Jihad on this thing again…<o
></o
