V
Vrotate
I'm having problems with my ignition, I can't get it into the lock position to remove my key. I have a manual 4+3 transmission. You have to put it in reverse for the wheel to lock and to remove your key. Now I put the car in reverse and can't remove the key.
Thinking its a linkage between the shifter and the steering column. Was wondering if anyone has had the problem and knew how to fix it. :duh
