LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
Driving down the highway on Friday....all of a sudden I hear and feel a vibration / engine knocking....rough running...whatever you want to call it. Get off highway and having trouble keeping it running....sounds like I have lost a cylinder or something.
Will not idle....runs really rough. Oil pressure is fine.
Long story short....I removed valve covers, everything appears fine and all are moving normally.
Pulled #7 plug out...it is wet with fuel.
Run engine for about 20 seconds and then using my hand check the temp of each header tube.....find that cylinders 4, 6 7 are much cooler than the others....okay burned hand on the others.....
I originally thought I had spun a rod bearing from the noise....but now I am thinking the ignition module has failed. Any thoughts????
UPDATE: 4/9....see my latest posting.
