LannyL81 said:
looking at the data in the chart, the intake valve closing, it should be 60 ABDC.
Yes. It is. I should have made my example consistent with an actual cam. :ugh
lannyL81 said:
Do not know the piston distance from top of piston to first ring, pistons are H631CP30..
I tried to find it on line, but could not find it. But the sample data that came with the software uses 0.3" height. I measured my with the Sealed Power H618CP20 piston in my Vette's engine, and those are 0.282. The difference between the two is a mere 0.01 in the CR. So can split the difference if you like and go with 0.291" if you like, but we're probably splitting hairs.
The 0.3" value is reflected on the chart as of now and the 60 deg ABDC value.
LannyL81 said:
...So new cam it will be. In fact all new top end. But this time since computer applications are readily available....I will be able to match the cam to the heads and finally have a proper working engine.
Gerry....would like your help and your program. I will send you the block measurements as soon as I can. Will also send the cam specs from what Comp Cams recommends using Cam Quest......need to determine if the 1.6 rockers need to be replaced...what chamber size heads to get, 64 or 70 cc.
Lanny,
I will help you with whatever I can, bro.
:L
You were saying earlier that your dampener has a 90 degrees scale on it. When you measure your TDC height of the piston in comparison with the deck, take the time to see if TDC is where the dampener says it is...just to make sure. Get that TDC tool at the local speed shop. Get the one used when the heads are off. You are gonna have to back it off TDC in the compression stroke and once the tool is installed, let the set screw to protrude just a few thousands of an inch. When you rotate the dampener towards TDC again, gently push it until it hits the tool above the piston. mark on the scale with a grease pencil the degrees. Then rotate the dampener in the opposite direction until the piston gently touches the tool again, and mark the scale on the dampener with a grease pencil as well. the exact middle between the two marks is TDC.
That gives you true TDC. It may come to be a degree off in either direction of the "0" mark on the dampener. The true deck height measurement can only be made with the true position of the piston at its true TDC.
On another subject, consider going back to 1.52 rockers and keeping the cam (if you want to save money). If you want to mimic a dual pattern cam (different lift/duration between intake and exhaust), you can opt to use the 1.6 rockers on the exhaust valves.
