Peer81
Are you looking at the normal XE series or the special computer XE series? I think the computer XE series has little overlap and you have a normal idle.
Greetings Peter
Greetings Peter
Gerry,
With this cam what does the numbers come out to be?
exhaust opens at 44 BBDC, intake closes 29 ABDC
112 LSA, 107 intake centerline
70 cc head, 0.038 gasket thickness, 4.190 gasket bore
Everything else is the same.
Thanks much...
Either way. The program has a calculation feature from 0.050" values, but it requires the lobe lift, and the duration at 0.050"...![]()
Duration at 0.050 is 204/214, lift is 280/295 (I think...I may have written that down wrong).
And here is the data with the Lunati Voodoo 60101 cam
The VooDoo cam looks to be the way to go....and a bit thicker head gasket....the 0.038 is matched to the Edelbrock heads and intake...but is just too thin for my application. Will have to get a FelPro head, intake, exhaust gasket set. I also need a front cover and probalby oil pan if I tear mine ....Lanny
Gerry or anyone....do you know if full roller rockers will fit under the stock valve covers?
Since I think I need to replace my 1.6 roller tip rockers with 1.5/1.52 I was wondering about going to full rollers...but do not know if they will fit under the stock valve covers or not.
Any experience with Summit or ProForm brands? The Comp or Crane are just too high $$ for me.
