T
t78
Hello Everyone,
I finally go my new vette to run on its own last night
but I still have one problem...
After a small tuneup (plugs,oil,airfilter,pcv,fuel filter) it was idling too low and stalling out, so I replaced the automatic choke, and turned the idle screw (on the throttle cable) about 1/2 turn. Now in Park and Neutral, it idles right around 1600 (what the engine sticker says it should). -with out stalling.
But once I put it into Drive or Rev, it stalls right out. (The sticker says it should idle around 700) If I hold the brake with my left foot, and give it just a little gas, it stays running, and I can drive it around. But once I get to a stop sign/light I have to put it in Neutral, or hold the brake while giving it some gas.
Is there an adjustment for the idle while it is in gear?
Any clues or suggestions would be great.
I have done all of the easy troubleshooting my guides have told me to, but still no luck.
I have also cleaned the carb out good, and all of the vacuum lines seem okay.
Oh yeah, it's a complete stock 1978 L82. With auto tranny.
also, it's kind of sluggish when first starting off, but once the RPM's hit about 2000, you really feel the engine pep up/kick in.
I'm not sure if this has anything to do with it.
Thank you,
t78
Thank you,
t78
