- Joined
- Oct 7, 2007
- Messages
- 720
- Location
- Amherst, NY
- Corvette
- 1996 Torch Red Coupe (Prior 1988 and 1989)
Incorrect fuel gauge readings on cluster - FIXED!!!
My cluster fuel gauge readings started to bounce around between what it should be and full. According to the FSM, at 0 ohms the gauge should read empty, 45 ohms it should be 1/2, and at 90 ohms it should read full. The cluster fuel gauge posted the right results using correct valued resistors, so my attention shifted to the fuel sending unit. After removing it from the tank (same process as replacing the fuel pump, and bleed the rails), I could now attach a VOM and measure the readings at different float levels. As I wiggled the float sideways at say the 3/4 position, the 60 ohms reading would spike up to 90 ohms or higher. Found my issue. Now how to fix it. First I sprayed contact cleaner inside the metal canister that contained the variable resistor. It helped some, but I was hoping for even better results. The canister has three tabs which I carefully bent back to open up the unit. Tarnish like buildup. Inside the variable resistor is a coil made of real thin wire, so I sanded it very lightly with 1000 grit sand paper in the directions of the wires (not across). Reassembled the canister and measured the results again without bending the tabs down. What a difference. Stable readings now on the VOM. Feeling that I solved the issue, bend the tabs down and reinstall the sending unit in the tank. 1.5 hours to complete from start to finish. After a few test drives yesterday and today, all is working properly.
A lesson learned: When I tested the cluster fuel gauge using different resistors, I discovered that the fuel gauge has a delayed response. So when you go from open circuit to a direct short of purple and black wirse, you need to allow time for the gauge to move to the correct reading. At first, I didn't give the cluster enough time to react, and I thought my cluster was messed up. It makes sense why the cluster is designed this way, but it threw me a curve for a few minutes. I could not find any comments about this delayed reaction in the FSM.
