gmboileau
I have read with great interest about the various problems with Multec fuel injectors and have discovered that this most likely the cause of the Code 45-rich exhaust on my 90 L98.
I measured the resistance of the injector on cyl 4 and it was about 5 ohms the rest were about 16 ohms. I used a scan tool to watch the O2 voltage and integrator values at idle and noted that the O2 voltage was steady at about 800mV and the integrator was 80 both indicating a rich condition. With the injector wire to cly 4 disconnected the O2 voltage fluctated as it should and the integrator climbed to 112 (not perfect but much better). It's seems hard to believe but with the injector wire disconnected the engine actually runs a little smoother at idle and the vacuum reading is a little higher.
I am going to replace the faulty injector and have noted that there are several options like Ford/Bosch pink tops ....however I would like to keep the car as original as possible and keep my costs down.
Any thoughts of my observations/conclusions??
Also, I was wondering if anyone had any Multec injectors 22lbs in their parts bin that they are willing to sell?
