Instrument cluster removal
Beobachter
MD
2006 Daytona Sunset Orange Roadster 1961 R/W
Want to install new instrument cluster in my 04 with the LED lighting. Where do I start to remove this cluster from the dash? Are all clusters the same? Is the Heads up display integral with this cluster or could I use another cluster from another C5 without Heads up?
Let me know whats up.
BOWTIE9025
PITTSBURGH, PA
CLUSTER REMOVAL
This is straight out of the gm service manual:
1.- disconnect negative battery cable
2.-remove I/P upper trim pad
3.-carefully lift the HUD display electrical harness from between the I/P cluster and HUD (if equiped)
4.-disconect the HUD connector from the I/P cluster (if equiped)
5.- remove the IPcluster to steering column bracket retaining screws.
6.- raise the rear of the IPcluster slightley to release the locator tab, then lift the IPcluster to access the electrical connector.
7.- disconnect the IPcluster electrical connector
8.- remove IP cluster
NOTE-- WHENEVER THE IP CLUSTER IS REMOVED FROM VEHICLE, DO NOT SET THE CLUSTER ON ITS FACE FOR MORE THAN 15 MINUTES OR DAMAGE TO THE FLUID FILLED AIR CORE GAGES WILL RESULT!!!!!!!!!
Reverse steps to install
9.-program the transmitters
10.-synshronize the transmitters.
sorry, could not send illustrations--protected.:upthumbs
Beobachter
MD
Many thaxs. Does the HUD work independently of the instrument cluster? Have another dash without HUD. Does the module for HUD just bolt into cluster assembly. Please advise.
tstar
Central PA
1999 Pewter Coupe
You don't have to remove the upper dash pad! I've had my IPC out three or four times already... Follow these instructions;
http://www.spdkilz.com/techtipleddic.html
All the clusters are the same and the HUD is an "add on" module connected via a ribbon cable that press fits into the top of the IPC;
Pic of me removing the HUD connector;
Here is a shot of the main connecor and the HUD connector on the right;
BTW which gauge faceplates did you get???? I've been trying to get Red into my IPC for months and have only found ONE company that makes an acceptable product but we need 23 more pre-orders before they will begin fabrication...
Take care...
Beobachter
MD
Thaxs. The site and pics are a real bonus. Now I think I can do this proceedure. I too was thinking red lights.
Most appreciated.
tstar
Central PA
1999 Pewter Coupe
You can't go wrong with Red! But I may be biased!!!! :rotfl
Beobachter
MD
Does the HUD simply bolt into the IP? Any C5 IP will work in any car? I am confused. Thax
tstar
Central PA
1999 Pewter Coupe
It bolts unto the underside of the upper dash pad and framing. The connector is a 10 pin slim line connector that press fits in. All IPC's have the 10 pin female connector on the top for the HUD connection, even 97 and 98s... So any Vette can fitted or HUD once you buy the HUD projector, bezel and cable...
