tHuelle
So I picked up my first corvette a couple months ago. A 90 z51. I've been going through it, there were a few things to do.
Anyway, a few weeks ago I got a check engine light. I used a paperclip to get the code and it was H25, high IAT temperature. So I ordered a new sensor since they're cheap. I pulled the old one today and realized they are quite a bit different. Now, these differences wouldn't normally bother me, but the problem is the connectors are different. The connector on my car won't plug into the new sensor.
Thinking I bought the wrong sensor (Maybe one for a zr1?), I went back to Napa with the sensor from my car to return the one I bought. When I got there, the guy explained that what I had pulled off my plenum was, in fact, a coolant temp sensor. He said you can clearly tell because of the way it's closed in and has sealant on the threads. I already know that the guy who worked on this before me wasn't that bright, but it'd be pretty difficult to get this wrong since you'd have to change the connector on the car.
I've attached two pictures showing the design of the two sensors and how the connectors are different. Could someone who has had their plenum off tell me what's going on here? Looking on Rock Auto and Napa, I see the one that he told me was a coolant sensor listed as both a coolant temp sensor and an intake air temp sensor. Weird! (Not that Rock Auto or other online parts stores are the most reliable source)
