silver00v6camaro
I need some advice on a carb and intake and torque converter. Currently i have a 600cfm holley 4160 but I do not think it is enough to get the job done. Comp cams says to ues a big carb for my cam. here is my specs on the cam. my motor is a small block chevy 350 bored over .30 with 10.5:1 compression. Car is a 75 auto with a th400.
Part Number 12-512-5
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS280TLS-6
Description
Intake Exhaust
Valve Adjustment 0.018 0.018
Gross Valve Lift 0.53 0.55
Duration At 0.02 Tappet Lift 280 288
Valve Timing At 0.05
Open Close
Intake 19 51
Exhaust 56 23
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 250 259
Lobe Lift 0.3534 0.3667
Lobe Separation 106
Recommended Valve Springs 986-16
This is what the guys used when they built my motor it was purchased as a kit so the question is what cfm carb do I need and what is a good one to go with.
262ci-400ci
8cyl.
Description
Intake Exhaust
Open Close
Intake 19 51
Exhaust 56 23
Intake Exhaust
Lobe Separation 106
