bschulze
Can you offer any hints as to how to remove the intake manifold on my 86?
It's been leaking coolant for years and I'm hearing the gaskets were poor, break down and need to be replaced.
A mechanic said from my symptoms, a 95% probability new gaskets will cure the leak. Any hints as to removing the intake?
Just start removing things? Injectors removed? Throttle body off? Try to remove the plenum first? Any hints?
Thank you,
Bob
Thank you,
Bob
