7
79-L-82
I want to replace the intake on the L-82 while I am cleaning up the engine and compartment.
I'm looking at a couple of different options.
My plans are for Hooker sidepipes next year.
I currently have a Holley 650dp and smog stuff removed except for the cat which will be leaving when I get the hookers.
Some day aluminum heads, but; that may be WAY down the road.
So Edelbrock Performer EPS, EPS Air Gap, RPM, RPM Air Gap or I was also looking at the Holley Systemax I and Systemax II which would come already with heads. (though, I really wasn't planning on a cam since I've heard that the L-82 cam is OK.
Any opinions on these intakes and / or the Systemax II?
I'm assuming that the RPM and RPM air gap will fit under the L-82 hood with a drop base air cleaner. (That's what I've heard at least)
Thanks in advance.
Thanks in advance.
