Greg Gore
- Joined
- Apr 30, 2005
- Messages
- 94
- Location
- Charlotte, NC
- Corvette
- 96 Coupe-white, LT-1; 04 Convertible-triple black
Oops…I should restate that. With the main throttle part way open when you move the choke butterfly by hand the fast idle cam should move along with it. If it moves without binding and does not stick it is operating properly. It could still be out of adjustment, however. The steps on the fast idle cam are staged to occur at various degrees of choke opening. A common adjustment procedure often in various shop manuals would be to place the fast idle screw on the second step against the stop and with light finger pressure moving the choke toward the closed position measure the opening at the top. There will be a spec for this and a convenient way to measure is with a drill bit. My goal would not be to blame anyone but you did pay a premium price to rebuild your valuable original carburetor and you received back a leaking unit. You said he was not very helpful and not very willing to work with you on this. For this reason I would favor posting something so others can be forewarned. They are not making anymore original components and we don’t need folks with poor or indifferent attitudes destroying these things unnecessarily.
Regards, Greg
Regards, Greg
