BarryK said:thanks Brian. i was under the assumption the choke was brought back to "open" (off) by the thermo spring heating up??
JohnZ said:To clarify - the vacuum piston connected to the choke (the "choke unloader") pulls the choke blade back a little (creates a 3/16" gap from the lower edge of the choke blade to the air horn opening) the instant the engine starts so it gets enough air to idle while the spring is still cold and coiled tight, tending to hold the choke blade closed. As the bi-metallic coil heats up (hot air from the exhaust manifold, through the heat tube), it unwinds and holds the choke blade fully open.
IH2LOSE said:Barry
As always sorry for your troubles,if the carb is leaking send it back, no questions ask. As soon as you tear into it the leaks will now be your problem.
Was this guy just a replater or did he rebuild it also
