Interior differences between the 90-96
rdgfx3
Rowlett,TX.
2008 Silver Coupe
Will some of the trim,specifically the doorsill trim on the rear of the door,interchange in these models?
Also,what is the trim panel to the right of the accelerator pedal called?Mine has broken,but I don't know what to ask for.:duh
Tallahassee, FL
none right now :(
I just saw two of those trim pieces on ebay (the ones next to the accel. pedal) Check that out.... also, the interior is a bit different through the years, I am not exactly sure what you mean by the doorsill trim... The doors are different for sure... a little more description could help me figure out if they will work or not.
rdgfx3
Rowlett,TX.
2008 Silver Coupe
Rear Doorsill trim.
Ok.uh ..as you open your door,this would be the trim that is on the striker part of the door.But inside,of course.
It goes from the bottom of the door in the sill to about the top of the door.At the rear of the door.
Confused? Me,too.
Sorry I can't be clearer with my description.:w
Thanks!
-=Jeff=-
Bartlett, IL. (Chicago Suburb)
1990 ZR-1
rdgfx3 said:
Rear Doorsill trim.
Confused? Me,too.
Thanks!
I believe it is also termed Dog leg. I think 84-96 are the same for that piece
rdgfx3
Rowlett,TX.
2008 Silver Coupe
Thanks Jeff.
Cool paint job.
Do you have an acrylic roof or a solid one?
-=Jeff=-
1990 ZR-1
rdgfx3 said:
Thanks Jeff.
Cool paint job.
I have both..
I got the Blue Acrylic roof with the car. Then stumbled across a White Solid roof for my car (was white before I had it Painted) off of a 1990 Vette a guy at work had sold with the Acrylic top.
I got the Solid roof (minus the mounting hardware) for $150 then paid $75 for the rest of the hardware and padding
