L
lheindrich
So I posted a thread the other day about my interior lights not working and I have not recieved any response yet so I decided to look a little further into things myself. I also checked old posts but have'nt found much help there. So first all my fuses are good, second I tested for voltage at the headlight switch and I have voltage at the orange lead and the red lead there are two brown leads a light blue lead a green lead and a white lead at the headlight switch. I checked other forums and they said voltage should leave the headlight switch on the green wire and run to the fuse box through the fuse then back out on the gray wires to the dash lights. So before I buy a new headlight switch I want to make sure that is the problem so I made sure I had good grounds first then I made a jumper from the orange lead with voltage to the green lead and still no interior lights. My question is have I done the proper trouble shooting to this point and if I have what could be wrong? Could someone out there in Corvette land help me because I am still in the learning process here and I do'nt know what to do next. Thanks for any input.
