justin10morrissey
okay so i was replacing the window ribbon on the passenger door and when it was all put back together the interior lights wouldnt turn off i heard that if u leave the door open too long and can overheat the timer and cause it to act weird also alot of the wires in the passenger door are frayed so i taped alot of them up the map light is unplugged bc the assembly is broke and the power door locks are also taped off cuz the rods are bent there was a light green wire and a light blue wire that i found that were frayed so i taped them now does anybody know if one of these wires or if anything is causing the problem it is blowing the ctsy light fuse and the radio wont turn on when the fuse is blown actually when theres a good fuse the radio turns on but the lights also stay on
