- Thread starter
- #21
Antz81
The dielectric grease IS NOT for heat transfer!
I had always believed that it was used for heat transfer (in this application anyway), but that the thermal paste (or grease if you prefer) Is simply a better product to use for the job.
I've just been doing some research, and it seems that dielectric grease is very good and helping with heat transfer. It is better than a bare metal connection, and almost as good as thermal grease. Some people have even used dielectric grease in place of thermal grease with no adverse effects.
toobroke, this doesn't necessarily mean you are right though. Dielectric grease is normally used to keep moisture away from electrical connections (It does have other uses also). It would seem like the RTV is made from a similar compound, but with a big difference, the RTV will act as an adhesive. This is why RTV is not suitable. You will discover this when it comes time to replace your module.
