XLR8
Gone but not forgotten
- Joined
- Jun 23, 2004
- Messages
- 6,662
- Location
- Mississippi Gulf Coast
- Corvette
- 2003 AE Convertible, 1998 LCRM Convertible
Hi all.  ;help
I'm experiencing intermittent problems with my right front tire sensor and key fob. At times all tire pressure monitor sensors register on the DIC as normal, then I'll get the Sevice TM Soon message and notice that the RF pressure isn't being displayed. Sometimes it is blank and other times it shows XXX. At the same time, I've begun having problems with my key fob. The sensor will fail to recognize my key fob command to lock/unlock the doors or open the trunk. I have gone by the dealership and let them test my fob battery but it is fine. I have tried reprogramming the key fob - sometimes it "learns" the fob, and other times it doesn't no matter how long I sit and hold the buttons. Even after it "learns" the fob, the next time I try to use it, chances are very good it won't work again.
Today the mystery deepened further. I was around my car for several minutes while at the shop for an alignment, and the locks cycled and the horn sounded several different times although I had the PASSIVE button on the fob turned off. The next time I tried to use the key fob to unlock the doors, nothing. Then when I arrived home, I tried it again and it locked the doors and the horn sounded.
I'm unfamiliar with the module involved, but someone else told me that the Tire Pressure Monitor sensor and the Door Locks are all on the same module or some such.
Is this true? Does it sound as though I need to replace the tire sensor, or the module, or both? I've done some research here but couldn't find any info quite like the issue I'm having. I would appreciate suggestions or input from others more knowledgeable than I am. I'm going to end up taking it to the dealership I'm sure, and I don't know anyone personally in the service department that I can count on.
As a sidebar to this issue: I hit a very nasty pothole last week with the right front tire. It wasn't clearly marked and I didn't see it until I'd already hit it. It had to have rattled my car pretty bad because it sure rattled my teeth! I had the car in today for a fuel filter replacement and asked my mechanic to take a look at the right front tire and wheel but he couldn't see any obvious damage. I only mention it because the sensor issues began soon after this incident. As to whether or not the two are related, I don't know.
Thanks for any help or suggestions y'all can offer.
 Jane Ann
  Jane Ann
 Jane Ann
  Jane Ann
 ad .
ad .
