74bigblock
For those of you who like to mod... if you could add 20 or more HP for $250, would you?
Jack said:By, simply changing the intake only (regardless which one, even if it's really +20HP) ... I doubt if you're gonna feel much more in the seat of your pants than a thinner wallet. 20 more hp on a civic is a lot ... but it's not so much on a BBC.
JACK:gap
windrider50 said:I'm in the process of doing the reverse, removing a Torker II from my BB, and putting a dual plane mainfold on. Picked up a L-88 hood to fit in under. Haven't quite got there yet, as I also swapped out the cam, and now in the process of replacing valve springs and seals.
74BB, if you're interested the Torker II is for sale.
NJ BB Ken
1BAD69 said:to pick up that much HP by changing your intake, wouldn't you really have to be choking your motor with the one on there now...if you are at 425hp now, i would be really curious to see the dyno after changing it....i change my LS6 highrise to an AirGap and all it did was move the HP and torque curve up the rpm's a few hundred..did not give me any more power....
what made the most difference was uncapping the JCL baffles in the side pipes..i picked up 30 rwhp by doing that...
Can I get 80 hp for $1000?
hardnoks said:you will never stop wanting more h.p.!so 200 now,500 later...just get a supercharger and cut to the chase!you want power,that's where to get it.or like me when i had my 95,you can nickel and dime yourself to death,with minimal gains,or go for the s.c. and turn 12's at the track.good luck.and yes i'd probably spend 250 for 20!
