stearnman
I was just wondering...as I do waiting impatiently for my Corvette to arrive via DAS from Dallas TX...is there any reference any where that someone, anyone, has put together showing a type of modification/horsepower chart?
I guess my thoughts behind this are as follows. I'm fairly certain that no one single modification will net you a maximum return of HP...as has been stated in many threads about modifications, mods are really meant to compliment each other.
For instance:
One person takes a stock LT1 Vette and does the common "open lid K&N filter", the result in HP increase is X amount. (assuming around 10 to 12 HP increase?)
Another person takes a stock LT1 Vette and does the exhaust system swap, the HP increase is Y amount. (assuming exhaust system swap net more HP than the above mod, around 18 to 20 HP?)
Putting the 2 together, you would think the total increase in HP would be around 28 to 32 HP? But, in fact, having the 2 compliment each other should help increase the overall HP of each mod, correct? (Open lid K&N: up to 12-14 HP?; new exhaust system: up to 20-24 HP?) So, complimenting each should net closer to 32 to 38 more HP?
I guess I'm just trying to find a way to have a better mods-to-HP look up system instead of trying to search the forums or using Google. Many of the things/info I find is all great and useful, just hard to decipher which mods have the greatest impact on a stock vs already modified car.
[Edit:] Fixed typos.
For instance:
