C
caseyk
In the recent past,I have posted threads about my headlight motor grinding,keyless entry not working,driver's door window problems,trunk lid release /fog light switch problems,tire pressure sensor problems,electrical anomolies,due to bad ground connections etc. and I have repaired a lot of these items as I can afford it,but it just seems like one thing after another. I was driving home today from work,in the rain(49 degrees),I hit a bump and my driver's side window fell down into the door,my DIC was going off about tire pressure and I was finally able to pull over.While it was raining,I dug through the back of the car and found a small pair of channel lock pliers and some electrical tape,I wrapped the end of the handle with the electrical tape and wedged it between the glass and the door panel,just to keep it up while I was driving.Once I was underway again I noticed that my oil pressure gauge was pegged out !!! I didn't get a check gauges light on my heads up or DIC.But when I scrolled through the gauges button it is showing that I have 128 lbs. of oil pressure!! I'm smoking mad at this point,I'm wet ,cold, irritated and freaking out about the 128 lbs. of oil pressure.WTF ?????? I am spent ladies and gentlemen call me a wuss or whatever but I can't seem to getr a break.
Out of patience,
Casey
Out of patience,
Casey
Jane Ann
I really appreciate you guys,again, thanks for the feedback!!
This job appears like it is going to be really fun!! :bash In the picture 004,the cable is stuck in behind the pulley.Should I cut the cable to get it out?As you can see in 002 the cable is bunched up pretty bad,it made a wonderful noise going up and down until it finally broke!!LOL!!
