godfather8421
New member
Hello,
Just found this site today! Anyway I have an 98 Coupe with 60,000 miles. The AC is not working properly. I wrote down the codes and reset.
At first the AC blew semi cool air and then it started sending out hot air. I have a dual control and both sides seem to blow out hot air now. From
my past experiance with other cars its been the actuater door but would really would like to hear from someone more knowledgeable. Also my control unit is very dim. I dont think this is related because its been that way for awhile. I would also like to know if this is perhaps the problem ( the door), then is very difficult to fix on my own.
Any help or advice you have is much apprecieted!
These are all the codes that come up:
10-PCM P1431H A1-RDCM B2283 H
99-HVAC BO#61 H A1-RDCM B2285 H
99-HVAC B0363 HC A1-RDCM V1064 H
99-HVAC Bo365 H A6-SCM B2177H
99- HVAC B0441 HC A6-SCM B2187H
99-HVAC B0446 HC A6-SCM Bo851H
AO-LDCM B2282 H A6-SCM V1160
A)-LDCM B2284 H BO-RFA C2120HC
AO-LDCM B2284 H
AO-LDCM V1064 H
Not sure if these indicated the problems but this is what came up
AO-LDCM B2284 H
AO-LDCM V1064 H
