6
69vettester
In all honesty My Mallory dual point W/tachdrive (no vacuum advance) worked faultlessly but I have to watch the dwell setting constantly and it is more difficult adjusting dual contacts than a single!.
Plus..even Mallory calls these systems antiquated, and suggest upgrading them to newer technology.
So I just ordered a...
MSD-8572 MSD Pro-Billet Distributor w/tachdrive and adjustable vacuum advance (has an adjustable mechanical advance also)
and the mandatory module has to be at least a series 6....
so I got a...
MSD-6200 MSD Ignition Control Unit (msd 6a module)..
This is the lowest level module you can add into the system, it has no rev limiter.
The big question I have about this new distributor is :confused
The new distributor comes with a vacuum advance. I know what the optimal advance curve is for my motor but Im confused about what to do with this vacuum advance. It is adjustable, but should I disconnect it because its just an emmisions standards requirement (I have a 69 car) or am I wrong about that and I should tune it into my 300 hp , holley 600cfm 4160 vacuum secondary manual choke system) in order to get optimal performance (I do consider MPG as important). Hope I described this accurately.
Any advice, suggestions, previous experience comments are greatly appreciated.
Thanks in advance....pun intended :L
TomC
PS..I can somewhat justify the cost of this new ignition setup..cause Im going to put a 355hp motor in next year and this new ignition will be swapping to that motor. Ill put the mallory back in my present motor and try and get a decent price for it!
so I got a...
TomC
