Here's a poser (for me at least)...
I noticed at one point yesterday, just before I got home, that the oil temperature reading was around 250° while the coolant temperature was right around 190°. So today before I took it out, and before I even started it, I checked the oil and topped it off just to be sure I had a full pan of oil, which by rights would keep the temperature lower, simply due to the fact that there is more volume. I wasn't that low in the first place, and the only reason it's low to begin with is the thing leaves its mark, just like a Harley.
Drip, drip...
At any rate, I was coming over the hill from
Toy4Hal's place in Palos Verdes and running around 3500-4000 rpm in fourth gear, uphill, just flowing with traffic and listening to how sweet the thing sounds, when I happened to notice my oil temperature gauge reading around 270°! :eek
The coolant temperature was right around 190° and the day itself wasn't hot at all (it was around 65-70° today). The temperature started to come down right away, and I'm running synthetic, so there really isn't a problem,
yet. I'm just wondering what in the hell could be the cause of this latest conundrum.
Around town, the coolant temperature stays around 190° while the oil temperature usually runs around 240° when fully warmed up.
I realize that the engine, making horsepower, is gonna get a little warmer than usual, but why just the oil? I'm running the
TPiS (Earl's) oil cooler too, right out there in front of the radiator:
ENGINE OIL COOLER
Even though radiator coolant is used to heat and cool the engine oil, there is a need for additional oil cooling. TPI Specialties has developed a thermostatically controlled accessory oil cooler kit. This kit allows oil to circulate through the engine until 180° is reached, at which point the oil is routed through the TPI Cooler Kit. Our kit lowered the oil temperature 35° during testing. This is a must for the serious enthusiast.
Kit available ready to install. Universal kit available upon request.
Comes complete with oil cooler, fittings, hose, adapter and instructions.
Now, I
guess the thermostat may be sticking, but...
Any suggestions? :confused
