S
spijker
knocking lifters sound in rebuildLt5 , HELP !
Hi guys ( and girls )
I just rebuild my lt5 engine completely , its still stock but has better exhuast,
a haibeck chip, a 3 piece K&N filter at the front, and some other small stuff.
Also polished camcovers and plenum in two tone.and used stainless bolts
instead of black original hexes.
NICE LOOKY LOOKY !( send pics later, first need to fix this ****y noise ! )
Renewed all i could and the vacuum pomp nicely turns of after 5-10 secs and
doesnt go on after that. No leaks enywhere and al seems to be hooked up
alright ( al wires,hose's etc etc.) so no error there.
Cams are set to factory spec's ( with the pins in cams etc.) so should be
oke.
Today i started the engine for the first time, and yes it run directly, BUT !!
I hear a mildly TICKING noise on both side's of my cam covers. It sounds like
the lifters make noise against the cams. Even after running it 2 times to max
heat ( at aprox 205 degrees when the fan's came on) and that means the engines run about 15 minutes ( 2 times ) it's still there.?
Because im not 500% sure i put al the lifters back in the same hole's ( id might
have mixed 1-2 peaces trough another) i think it maybe can be that problem.
Ore maybe it takes much longer before or all the lifters have enough oil, i dont
know ! ( i have heard it should go away after a view minutes.
DOES ANYONE have or had the same experiences ? does it suppost to go away after driving it a view ( or more ) mile's ?
Does ( if i misplaced some lifters in the wrong original holes) it go away at all?
Is is a problem ?? ( sound is a ticking sound, but not that im getting scared of
it ! )
ANY experience's are welcome, please advice.
Im from Holland, so not so much expirience's over here with LT5's
Await you advice / finding with great eager !. I'll dont wanna drive it unless
i know what / might be a problem or not ...
WKR
Fred
zr1'91 Geiger corvette.
oke.
it ! )
WKR
Fred
