81l82
Does anyone know just how many L82's were made in 1981?;help
Thanks! I have owned the 81 since 1984, a one owner. I was told it was a L82, it has L82 badges on the front fenders. The stats always said 81's had a monoleaf spring, mine has a multileaf spring. It was born in 1980 in St Louis- Black on Black. When I tried to get a build sheet from NCM was told the records were lost in the move from St Louis to BG. Someone, somewhere knows the facts. Thanks for your help.
Thanks! I have owned the 81 since 1984, a one owner. I was told it was a L82, it has L82 badges on the front fenders. The stats always said 81's had a monoleaf spring, mine has a multileaf spring. It was born in 1980 in St Louis- Black on Black 4 speed. When I tried to get a build sheet from NCM was told the records were lost in the move from St Louis to BG. Someone, somewhere knows the facts. Thanks for your help.
The records show NO L82's for 1981. The ONLY engine option for 1981 was the L81 (350 cid / 190 hp)....I have "heard" rumors that a few L82's found there way into 4-speeds during early production, BUT I HAVE NEVER seen it documented anywhere ...
There were no optional engines for '81, so there were no L-82s.
As far as rumor control goes, (a few L-82s with 4 speeds) you are confusing 1980 production with 1981. Apparently a few very early 1980 L-82s may have gotten 4 speeds, but most of them were automatics.
Standard suspension cars in 1981 and 82 got the fiberglass rear springs. Cars with the optional FE7 package got steel springs. If your car has the optional FE7, it will have the steel spring and a rear sway bar.
A previous owner has added the L-82 badges. Pricey these days, but cheap back then.
PEER: No L-82s were installed at Bowling Green. The last L-82 was for the 1980 model year and that would have been St. Louis production.
The NCM does not have records for St. Louis cars. Contact Allied-Vaughn through the forum here and see if you can obtain a copy of the dealer invoice for your car. If they have your VIN on record, they will charge your credit card. Worth the cost. I was able to obtain a copy of the dealer invoice for my 80.
http://www.corvetteactioncenter.com/infosearch/index.php?cmd=area
...At my age I'm lucky I remember how to get home from the Coffee Shop....
Ooohhh!! I want to add confusion as well!!!to add confusion to the mystery, it sounds like you may have an 80 (to me)
Additionally, the valve covers were finned magnesium units on the 81. On the 80, they were stamped steel.
...an 81 engine:
