L98 longer connecting rods questions
  • Thread starter Thread starter tmcorvette
T
tmcorvette
We modified connecting rods and pistons (eagle 6.0" pres pin rods and Federal Mogul Performance flat top non-stick pistons (10.7to1 comp)
) in my 1988 'Vette, the crankshaft and camshaft are stock. No frisbie, no front katalysators, TCI shift-kit...
Does anybody estimate my actual torque and horspower? (factory data: 240HP, 340 lbf-ft) Is this increase fuel economy?
Thanks. :)
With a longer rod, you get greater cylinder pressures, which in turn produce greater torque. But horsepower increase would be negligible unless you were to replace your camshaft, to allow more air/fuel in, and to get it out quicker.
You also my want to note the willingness of the engine ro rotate. Since you've upped the compression, with no other modification, I doubt it will rev as high or a freely.
The best way to get a true measurement is to get it put on a dynomometer. You can get the Horse power and Torque and they'll plot it out, so you can see what the change is and where it is.
Lots of Luck
Thank You. :w
Lots of Luck
