- Thread starter
- #21
N
noel
thanx again would have taken me forever to find those
noel
noel
noel said:thanx again would have taken me forever to find those
noel
noel said:the only thing i am not sure about exhaust is what headers the rest will be 21/2 with x pipe & magnaflows & KN & thinking more about 383 crank tb i guess will depend on intake am not sure on that i guess what ever i can get the best deal on not building for track so whatever can get best bang for buck other stuff like rocker, injectors,cam,lifters well be a budget thing .looks like Ill be for some used parts am gladi have a few months to look for parts & put it all together
noel
fast.asleep said:Try a different brand. Hedman, Hooker and TPIS all list headers for the '91
intake: greatly depends on what you want out of your car and any future mods you plan to do. check this out: http://www.stealthram.com/intakecompare.html
87blackroxi said:Not to sidetrack the thread, But I have a question on the Lt1 intake. I have considered the Lt1 for a while. on the link above it says the Lt1 intake are better high rpm intakes (4000-7500) which would be good for the l98 because mine dies out around 4800rpms. But would you lose low end torque? Or would this make the l98 a new monster with it's already great low end, and add upper end?
Edmond said:What makes the L98 a low end monster are the long runners which allow for the air to enter the intake at a high velocity. With the LT1 intake, which is basically the MiniRam intake, the runners are much shorter. You don't lose much, if any, overall power but the power is moved further north on the RPM range.
Also a waste of money under 400 cid.fast.asleep said:larger throttle body (52mm, 58mm) is a waste of money on a stock L98 unless you make the openings in the plenum larger.
