S
SpartanSith
The `94 Caprice i have gotton has a 4.3L L99 in it, or is supposto given that year and the engine size listed under the hood. this is supposto be just a under-bored, under-stroked version of the LT1, and has something called sequential-port fuel injection that it uses, it looks like it should be able to bolt up to a L81, but im not sure about the distributer, cause the L99's sticks out the front, will i have to modify the intake, or is there a good aftermarket one out there?
any idea if the heads on the L99/LT1 would be a performance bump on the L81?
anyone ever tinkered with this instead of normal TPI?
thnx once again,
SpartanSith
thnx once again,
SpartanSith
