IH2LOSE
- Joined
- May 24, 2001
- Messages
- 3,908
- Location
- We Will All Meet Again
- Corvette
- 1966,and a 1962 thats almost complete
So here is the latest update
MAN OH MAN am I happy I did not attempt to install this the night before carlile.
Today I had time to sit and play with the engine before a party we had at the house today
I hope no one get me wrong this is a simple to adjust set up
Progressive linkage easy to adjust
But I made some mistakes
1-was running the car out of gas and assuming it was a mechanical problem
2-was trying to tune it with a disconnected vacuum line (it fell off the T for my vacuum gage
One of the problems I had was a stumble off idle Easy to figure out right have the idle misadjusted
Well a couple of hour going in and out with the idle circuits and still have a stumble,
My brother inn laws show up for the party early as usually.
I set up the vacuum gauge, timing light and tachometer and hand them the tools , the first thing my brother inn law notices is the accelerator pump on the front and middle carb are rattling in the breeze BINGO 2 seconds of looking at the carbs and he caught it. I was so busy playing with the adjustment screws and watching my vacum gauge I completely over looked the accelerator pumps.
A qick adjustment of the axcellarator pumps and the car now is real crisp off idel
Always pays to have a extra set of eyes to double check things
Well its a real cool set up Pulls real hard all the way up to the chip. It kinda spools right up to the chip like a two stroke
But I am back to square one with the trans.I have set it as the directions say but the car is short shifting again on a gradual throttle. Shift around 1800 rpm.
On a full throttle blast on a roll she is sluggish
but on a full throttle blast from a stand still it shifts Thu all the gears right up into over drive with the tires spinning the entire time as long as I can keep it kinda pointing in the correct direction.
I think it all has to do with it short shifting and the motor not making enough power pull hard because the motor is being lugged.
If I shift it as a manual trans (starting in first ,then shifting to second at 5000 rpm etc etc) the car runs like an ape. but if I just drive it normal with the short shifting its a turd
I will speak to bow tie overdrives on Tuesday and see if they can help me figure this out or I am going to switch to a six speed
