Donne Trav
Stripped Oil Pan Threads?
Some few years ago, when the dealership was changing my oil, the threads on the oil pan were stripped slightly. I didn't notice this until I began changing the oil myself. I had to take special precautions when replacing the drain plug ( doubling the washers seemed to work). I changed the oil a couple of weeks ago and noticed an oil leak at the "oil drain plug". I believe it's because of the stripped threads on the oil pan. Where can I purchase a "Self-tapping"/over size oil drain plug for my 1994 LT1 Corvette? Also, are any of you using the "Quik Valve" (no mess) drain plug apparatus? Does it work? Changing the oil gets quite messy at times. Thanks
