Viet Nam Vett said:I hear yah John.. I didn't believe him either. I was just stiring up the mud and beating the drums to get the Boy's worked up..![]()
How worked up do we look?
:gap
67HEAVEN said:How worked up do we look?
:gap
67HEAVEN said:I'm the handsome one. :gap
:gap
Viet Nam Vett said:Heh Bob ..Subject change...... What is the final base timing less Vacuume advance you used on the Heaven??
67HEAVEN said:8° BTDC @ 800 RPM, 36° Total @ 5,000 RPM
Spark Timing: (Disconnected) 36° at 3600 rpm with Distributor Vacuum
Viet Nam Vett said:And.....Where did you find the "Degree" Mark On your Keyboard....???? Mine only has the " * " instead of the little "o" . Neat-:L o.....Is that like a special techy key board you have their?
BarryK said:on our Mac computers it's even easier - no need to remember codes. There is a drop down menu and just choose the special character you want from the palette and double click it and BOOM, you have it.
stepinwolf said:Keyboards are different from one PC to another, however one thing they all have in common, is the ability to generate identical ASCII codes, ( pronounced "ask-kee" ).
If your keyboard doesn't happen to have the little ( ° ), then to reproduce it all you have to do is learn a few keystrokes. To generate these codes you must do the following in this exact order.
#1 Press and hold down the "alt" key
#2 Using only the numerical keypad on the right side of the keyboard, enter the three digit code for the character you wish to generate. in this case it's 248
#3 Then release the " alt" key, and the character ( ° ) will magically appear
You can also get a slightly larger little "°", by using the 167 code. Look at them both side by side ° º, isn't this tech stuff great,
The complete list of all the special characters your keyboard can generate can be found by linking to the following site.
www.asciitable.com
How does that grab you![]()
Stepinwolf
stepinwolf said:VNV,
I'm not one to argue the point, but if you followed the " exact procedure " and were not able to generate the caracter, I believe you have the only computer in the world that can't do it. :ugh
Stepinwolf
