Hi all I have picked up a 87 late November this is my first , I am having trouble with the lights in the door panels they wont stay off. is there a fix for this or do i have to replace them if so where can i get them?
Each door panel light does have a switch that lets them operate independently as map lights. Its possible each switch is faulty but its also unlikely that both would fail at the same time. The switches themselves can be repaired or upgraded.http://corvette1984.freewebtools.com/DIRECTORIES/REPAIRS/ReadingLampRepair/RLRepair.html
Are your other interior lights functioning? The door map lights,footwell lights and sail panel /hatch lights are also controlled by the headlight switch. The headlight switch knob when turned has a setting to keep the interior lights on at all times.
Since it shuts off then comes back on its likely the interior light delay timer. If it failed its over $100 to replace if you can find it. However, it can be bypassed so the lights just shut off when you close the doors. Its simply jumping a wire in the harness under the dash on the passenger side. There is a thread on here somewhere. I really need to add that fix to my website!
Are the switches a dealer item?
thanks do you think will NAPA have the switch i am sure i can install it
NOW HEAR THIS!!!
i spent in excess of 500 bucks for the same problem
it turned out be pilot error
i wasnt returning the door lock to its full upright position.
make sure the key is vertical when you remove it
